Power Up with The Spark Portable Charging Station
1234Next >
13232 144 2017-11-16
DJI Grace
Flight distance : 405039 ft
Hey, DJI Grace here! Today I would like to share something about Spark batteries. Enjoy! The following article originates from: BUYING GUIDES
DJI just released the Spark Portable Charging Station. How many batteries can it charge? Is it easy to carry and use? We will explore the features of this powerful charging station and answer all your questions.
The highly portable Spark portable charging station supplies power to Intelligent Flight Batteries and smart devices wherever you go with an impressive amount of charge capacity. Without removing the battery from the aircraft, you can simply place Spark into the station to begin charging, and the Charging Station features two additional charging ports for
spare batteries.
The charging station has a capacity of  5000mAh,54Wh and a voltage of 13.05V. When fully charged, it can charge up to three Spark batteries in just 150 minutes.When connected to an external power source, the Charging Station will charge itself as well.Using the USB port, it can also provide power to mobile devices such as smartphones or tablets.
Usage
1. Toggle the board’s securing switch to open the board and then align the battery with the battery slot track and insert it. Align the external charging contact on the aircraft’s battery with the charging station’s contact, and then insert the aircraft into the station. Close the securing board and ensure the board is fastened.
2. Short press the power button once, then press again and hold to power on the station to start charging.
3. When charging, it will first charge the battery in the aircraft, and then the two spare batteries in accordance with their power levels from high to low.
4.  The charging station’s charger is compatible with the Spark‘s battery charger. It takes approximately 95 minutes to fully charge the station.
5. You can also use this station as battery charging hub. When it’s connected to an external power source, it takes approximately 3 hours to fully charge the station, an aircraft-connected battery together with the other two spare batteries.
6. There are three ports on the side of the charging station. They are(from left to right):
  • USB Port (5V/2A):  to charge remote controller and mobile devices;
  • Charging port : to charge the station and intelligent flight batteries;
  • Micro USB port : to connect the station to a computer for firmware updates.
Now you have a way to stop worrying about running out of battery on the go.  No matter if you are out for a bike ride, a long hike or a road trip, you can easily pack the Spark Portable Charging Station and enjoy a long flight.
2017-11-16
Malakai_UK
Flight distance : 536115 ft
Take my money!! Any UK suppliers have this yet?
2017-11-16
jksphoto
Flight distance : 114121 ft
Sweden
Malakai_UK Posted at 2017-11-16 03:03
Its available on the DJI website
2017-11-16
Edd_88
Cost= 2 batteries, weight = 5 batteries, will charge 3 batteries on the go, is it worth?
2017-11-16
andwluv
Flight distance : 167241 ft
Malaysia
Wow! Awesome!
2017-11-16
DJI Grace
jksphoto Posted at 2017-11-16 03:13
Thank you so much for your reply
2017-11-16
DJI Grace
You can complete the purchase on our store.dji
2017-11-16
droneflyer101
Heliguy have it on pre-order https://www.heliguy.com/dji-spark-charging-station-p4779+
2017-11-16
Malakai_UK
DJI Grace Posted at 2017-11-16 03:43
Thanks but your shipping cost are unreasonable.
2017-11-16
rarevfx_officia
Flight distance : 387562 ft
Edd_88 Posted at 2017-11-16 03:20
yes. Since freshly powered batteries are worth more than batteries that are powered up hours ago
2017-11-16
jyc
Flight distance : 2246224 ft
Very cool, I might just get one.
2017-11-16
heliman
Denmark
150 minutes charging 3 batteries.
Is that charging one battery at a time, with 50 minutes for each?
2017-11-16
jksphoto
Sweden
Malakai_UK Posted at 2017-11-16 04:07
This statement is 100% correct, looked to buy the Pgytech Skins Pack, £14.00
They want £10.26 shipping, how much does a box of vinyl skins weigh
2017-11-16
jksphoto
Sweden
And you have to pay an additional £17 for a charging station bag to carry it in. Come on, surely that should be in the price
2017-11-16
S-e-ven
Flight distance : 5910961 ft
Thailand
Is it charging with only 2 batteries and WITHOUT Spark in the Station? If yes: How long will that need?
2017-11-16
jksphoto
Sweden
S-e-ven Posted at 2017-11-16 05:47
2017-11-16
S-e-ven
Thailand
jksphoto Posted at 2017-11-16 06:19
Yep, but if there is no Spark inside?
Because without a Spark and a third battery, the two could be the first flown batteries.
And you can fly with the other 1 or 2 or x batteries, during you charging already the first 2.
And charging should be quicker.
How long would be the time for only one inside?
Just trying to find out what is possible.
2017-11-16
Drone-Mike
100% buying this!
2017-11-16
SparklingPraf
Flight distance : 193983 ft
I think this only looks good, but I would prefer the Smatree charger over this anytime. Cost: $60, shipped, Weight: 800g (100g more than DJI's) Capacity: 8100 mAH  (can charge 6 spark batteries) but where it shines is it can charge 3 batteries in JUST 40 MINUTES.
https://www.amazon.com/gp/product/B075K7V42Z/
The only downside I see is it would take about 10-15 hours to charge it using the stock 5V 2A charger. I wish Smatree would come up with a fast charger for their charging station soon.
2017-11-16
pigolato
Flight distance : 745243 ft
Hmmm.... 89 dollars in USA, £89 in UK. No thanks.
2017-11-16
Malakai_UK
SparklingPraf Posted at 2017-11-16 07:28
Cant wait for this to become available in the UK
2017-11-16
Zbig
Flight distance : 7349 ft
Poland
Too bad about the power connector being located on the front of the station. A bit unsightly, if you ask me. I understand the USB port being there, for charging your RC but I envision the station sitting in its dedicated spot on my shelf, connected semi-permanently when I'm not out and about. The power cable sticking from the front (official photos won't show you this ;-)) kind of ruins the aesthetics. Not that it stopped me from ordering, mind you... Also, I wonder if DJI opted for some standard form-factor Lithium-Ion cells like 18650, making them possible to replace should such a need arise, officially or otherwise.
2017-11-16
Ryan's Sparky
Flight distance : 302316 ft
Norway
I'm loving this!  but I have 5 batteries... haha
2017-11-16
Nikon 1
Ordered via the DJI store.  Delivery quoted within 2 weeks.
2017-11-16
theGrindLab.com
Flight distance : 1375846 ft
I see your point. I would just get 2 or 3 more batteries to take with me.
Update: Never mind. At only $89, it does have value.
2017-11-16
Agent Sgt. Shad
Flight distance : 500679 ft
If they made one for the Mavic Pro as well, I'd definitely get that type!
2017-11-16
AWACS
Flight distance : 16798 ft
aswsome ! I just want one ASAP!
2017-11-16
S-e-ven
Thailand
Ryan's Sparky Posted at 2017-11-16 09:11
Which would be exactely perfect, if 2 batts could be charged in there.
Or even 3, but without Spark!
Fly, fly, flycharge, flycharge,flycharge, flycharge, flycharge, flycharge, fly,fly,fly,fly,fly
But in case the Spark has to be in there, too?
Pass!
2017-11-16
DJI Elektra
You can buy it on our website. Here is the link, it is available now: https://store.dji.com/product/sp ... m=search-result-v2.
2017-11-16
DJI Elektra
Agent Sgt. Shad Posted at 2017-11-16 18:06
Glad you like it. Your requirement will be reflected.
2017-11-16
Malakai_UK
DJI Elektra Posted at 2017-11-16 22:53
You can buy it on our website. Here is the link, it is available now: https://store.dji.com/product/spark-portable-charging-station?from=search-result-v2.
Thanks Elektra, I would rather wait and order it from a UK supplier, your shipping costs are way overpriced. Over £10 is rather high when most UK suppliers will either offer free shipping or ship a reasonable cost.
2017-11-17
Brightlights200
Flight distance : 1001 ft
Hi,
Just to confirm is shipping to the UK £10.26 please?, as when I went to pay via PayPal(from the DJI site) it didn’t charge me anything for postage but when I went to pay via Visa card it asked me for my full address but did not ask for my Country(is this automatically set via the website?) just City/Region/Postcode/Zipcode.
I just want to make sure it ships correctly & I’m happy to pay £10.26 shipping, Please advise
2017-11-17
Brightlights200
Hi,
Just to confirm is shipping to the UK £10.26 please?, as when I went to pay via PayPal it didn’t charge me anything for postage but when I went to pay via Visa card it asked me for my full address but did not ask for my Country(is this automatically set via the website?) just City/Region/Postcode/Zipcode.
2017-11-17
DJI Elektra
Brightlights200 Posted at 2017-11-17 03:16
Hi,
When you buy the products from our website, you should choose the country at the upper right corner. So please ensure that you choose the right country and here is the info for your reference.
2017-11-17
DJI Elektra
Malakai_UK Posted at 2017-11-17 01:26
I see. Here is the link of retail stores, please take it as reference: https://www.dji.com/where-to-buy?site=brandsite&from=footer.
2017-11-17
Malakai_UK
DJI Elektra Posted at 2017-11-17 03:58
Thanks Elektra, ill get in touch with my local DJI reseller, see if they can get one in.
2017-11-17
Brightlights200
DJI Elektra Posted at 2017-11-17 03:49
Hi Elektra,
Thanks for that but if I wish to purchase via PayPal due to protection for purchases will it add the shipping fee once I hit the payment button as it’s not showing any shipping fees prior to that when I use the PayPal button from your site?.
2017-11-17
Brightlights200
Hi Elektra,
2017-11-17
Brightlights200
@Elektra,
I’ve paid via PayPal & thankfully it did add the shipping cost but not until you’d confirmed the order & pressed the pay option.
I’m  Looking forward to receiving the charger not only for it’s main purpose but also to help carry it all together safely & storage at home so my Good Lady can stop complaining about “My Mess”.
2017-11-17
Viking-Pilot
Flight distance : 2379249 ft
This is awesome, looks great, maybe I'll get me one of these, but i have my power converter in my car so I can use my charging hub and I also have 7 batteries so I can fly, fly, fly, fly alot
2017-11-17
1234Next >
