Dockater
Flight distance : 139649 ft
I hear often about GPS in phones and pads, should it be on? Should it be off? Let us put paid to this confusion and examine some facts.
Your iPhone or iPad does not have a satellite finding GPS system. Lets look at some simple facts and see how your pad or telephone works out its location.
Every iPad ever made has both WiFi and Bluetooth, two wireless technologies for connecting to nearby devices (in the case of Bluetooth) and the internet (in the case of WiFi). The only additional option is to add a cellular module, originally called 3G and now called LTE for the latest models. This cellular option allows the iPad to connect to the internet anywhere your cell phone works.
In addition to the cellular radio, the 3G/LTE models of the iPad also have a built-in location receiver. Apple calls this “assisted GPS,” which is probably where the confusion comes in. By assisted GPS, Apple means that the GPS receiver in the iPad can use nearby cell towers (fixed antennae stations) to provide a faster position lock (what engineers call “time to first fix”). Instead of starting up cold and searching for satellites, which can take up to a few minutes in some cases, the iPad knows right where to look. With a hot start like this, your iPad can find its location in just seconds without satellites.
The DJI aircraft (ac) is responsible for finding satellites and determining an accurate GPS position. The ac sends its position at 0.1 second intervals to the controller where it is used to set the home point, to calculate such things as distance and speed and navigate a predetermined plan if required. The “flight log” is used to store this and much more information about the flight. The ac knows where it is and what it is doing better than most pilots. That is how the ac can still find its way home even if you “Semtex” your controller, phone and pad during a flight.
Your pad or mobile telephone can be used in any mode you wish. It is advisable to put phones into “flight” mode to stop interrupts from incoming calls, messages, emails etc. A pad with cellular capability or connected to a WIFI during flight will have the advantage of supplying a map during the flight but will not compromise ac navigation. If you want a map but have no cellular capability you can cache this at home with WIFI available. An alternative in the field is to use your cellular phone as a “hot spot”.
