OSMO BLACK SCREEN HELP!
10312 14 2017-11-16
GeraLuna
I have troubleshot everything:
1)Remove SD Card
2)Externally format sd card
3)Install the firmware on the sd card
4) Made sure DJI Go 4 is not running in the background
The symptoms:
1) Solid left led yellow light ( I know this is SD CARD problem, but even without a card gives trouble). Solid right green light
2) A Black Screen
3) gimbal is responsive to stabilization and movement.
I use it professionally so in a rush I ordered a second one to arrive tomorrow via Amazon.  Makes me want to invest in a regular gimbal instead.
Any suggestions? Thank you so much for your help.
2017-11-16
May I know the model of your mobile phone? Have you tried other mobile device?
Have you tried to reset WIFI to the default? Please refer to the tutorial video below and let us know if it helps:
2017-11-16
GeraLuna
DJI Mindy Posted at 2017-11-16 23:27
https://www.youtube.com/watch?v=lxB5uOoDQUU
Thank you, I'm going to try this.  The inital issue started while on a google pixel xl, but I had the same issue with an ipad.  Trying your suggestion.
2017-11-17
GeraLuna
Mindy, unfortunately It didn't work.
2017-11-17
DJI Elektra
GeraLuna Posted at 2017-11-17 07:49
Did you have the log of upgrade in the SD card? Can you search the wifi of osmo? Please try to use the original SD card to upgrade your osmo. Keep us updated if the problem remains.
2017-11-17
vit157
Czechia
DJI Elektra Posted at 2017-11-17 23:06
I tried all those procedures too, and still get black screen.
Please advice on this
2017-11-22
DJI Elektra
vit157 Posted at 2017-11-22 23:46
Please provide the upgrade log for further check and you can post here. Thanks a lot.
2017-11-23
vit157
Czechia
DJI Elektra Posted at 2017-11-23 02:23
here is the log file
2017-11-24
vit157
Czechia
Hi!
Any reply on this?
2017-11-28
Nebuchadnezzar
Flight distance : 3462946 ft
vit157 Posted at 2017-11-28 00:18
Hi!
Any reply on this?
apparently the update was completed correctly, but you should wait for someone who knows exactly. Did you try reinstall the app ?
2017-11-28
vit157
Czechia
yes, I did. Even without app camera records damaged videofiles...
2017-11-28
vit157 Posted at 2017-11-28 01:11
Have your tried to remove the SD card to see if the image will recover?
Besides, please dismount the gimbal to check the connector in the handle.
If everything is normal, I'm afraid the device will need to be sent in for diagnosis and repair.
2017-11-28
vit157
Czechia
hi, yes, everything is fine.
Is it possible that android app version is faulty?
2017-11-28
Don Logan
Flight distance : 164531 ft
I had this problem with my Osmo as well. Turns out the pins inside the handle were bent. Jay at the local DJI store was able to correct the problem in just a few minutes.
2018-10-30
diiego.phpgmail.com
Brazil
Don Logan Posted at 2018-10-30 19:20
Quais pinos estão tortos , estou com o mesmo problema e não consigo soluciona-me me ajude por favor
2021-2-21
