Labroides
Flight distance : 9991457 ft
the compass stops working mid flight
The compass doesn't usually stop working and if it did, you would not be able to control the Phantom at all.
A compass error is usually a good compass telling you that it has detected a magnetic field that's different from the earth's normal magnetic field.
Look around at where you are flying to see if there's an obvious magnetric influence.
Are you launching or flying close to a lot of steel or reinforced concrete? |
