Mundus
Denmark
ALABAMA Posted at 2017-11-18 05:21
I also think that the motor shaft has to be in a certain position, Don't think it has a flat end side. You could try different positions to see if it makes a difference.
Hi, many thanks for all the good suggestions.. have tried them all. I can’t see that it is possible to mount the yaw mother wrongly on a p4p, it is rather fixed in its mount I.e. apparently no way to adjust or “zero” the position. I will try to post a video... as suggested!.
Tried:
New yaw motor, new yaw arm, new ribbon cable, new vibration damper, calibration normal and vertical followed by all the rest of the normal calibrations... non of it have had any effect...starting to think that I might have received a faulty yaw motor.But also on this subject... I have build more than 20 drones by now mostly race drones but also 4 DJI flamewheels with gimbals and all the trimmings.... they can take a beating! The Phantom 4 Pro is extreamly sensitive a short trip into the trees and you are in my situation - sucks!
