Mark The Droner
Flight distance : 2917 ft
A windsurfer - or a properly designed deflector placed on an omni antenna - changes the omni antenna into a directional antenna. If aimed correctly, as a transmitting antenna, it will give the receiver better signal strength and therefore better distance. As a receiving antenna, it will amplify the incoming signal and therefore make a weak intermittent incoming signal a solid signal. Either way, it extends the range of the connection.
It has other advantages. For example, if you know you have interference coming from behind you but not in front of you, the windsurfer will block much of the interfering signal coming from the back.
However, aiming correctly is critical. A poorly designed windsurfer or a windsurfer not installed correctly or not aimed correctly can result in no advantage, and it can even make the signal worse by interfering with itself (due to half-wave phase-shift) or by amplifying an interfering signal that's in front of you.
Years ago, hobbyists were using Pringle cans. And yes, they worked. Range improved. Pringle cans, however, may not work as well for 2.4 ghz as they do for 5.8. So if your deflector looks like a pringle can, be wary.
The original windsurfer was designed here, copyright 2002, and was primarily used for routers: http://www.freeantennas.com/projects/template/index.html
Within a few years, it evolved to this: http://www.freeantennas.com/projects/template2/index.html
This design works for both 2.4 and 5.8 It's all over the internet. Sometimes the designer at freeantennas.com is credited, sometimes not.
The two stock omni antennas sticking up on the more modern drone controllers makes this design obsolete due to their width, since two of them won't fit side by side. Forcing them to fit won't work well for you.
Don't do this: https://phantompilots.com/attachments/20150710064257-jpg.24436/
The others which have appeared over the past year or two are more narrow. They probably won't work as well as Erskine's design, but clearly they add something because pilots have been reporting great distances achieved with the deflectors. Some sellers have even included Erskine's original drawing on their own site in an effort to promote sales, even while they don't use his design:
Take a look at the P3 leaderboard and count how many pilots use windsurfers and where they are ranked relative to those who use stock alone:
https://phantompilots.com/thread ... -leaderboard.76464/
I have a buddy in Iowa who is a world class distance pilot and holds the world record in one-way suicide mission distance for a Phantom (19.4 miles), and when I told him I bought a new drone, the first thing he told me was "get a windsurfer."
Hope this helps.
