Update Error 0x020106
12Next >
9020 67 2017-11-17
Sandman
Flight distance : 159760 ft
Pretty dissapointed DJI, went to fly my mavic the other day only to find it locked out and unable to launch due to a mandatory update. Meant I had to give up that days shoot and go home. This morning have been trying to update the mavic to your compulsory firmware v01.04.0000 for the last two hours and the update continually fails. I have tried it both via the RC (with phone app) and via DJI Assistant. Both fail. I used three different batteries fully charged. The error I get in DJI assistant is 0x020106
Pretty poor form to force a broken update on users, essentially grounding them until you can sort out your own mess.
2017-11-17
jake31
I am having this same problem. Tried updating via RC and Assistant and have wasted 3 hours and still cant get my drone off the ground. I keep getting error 0x020106.
Very disappointing to say the least...
2017-11-17
DJI Susan
Could you tell us your DJI Account(the email address when you logged in DJI GO)? I'd like to help you get the beta and try again.
1.Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11. or V1.3.8.13
3.Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest one, it will be working.
2017-11-18
DJI Susan
jake31 Posted at 2017-11-17 18:23
Jake, please refer my reply in 3# and tell us your DJI Account, thanks so much!
2017-11-18
jake31
DJI Susan Posted at 2017-11-18 01:08
I've PM'ed you yesterday but still don't see the beta on Assistant.
2017-11-19
DJI Susan
jake31 Posted at 2017-11-19 13:00
Received with thanks! The beta firmware is available in your account now, please try to refresh.
2017-11-20
jake31
DJI Susan Posted at 2017-11-18 01:07
I have updated to V1.3.8.13, but when I then try to upgrade to the latest firmware it still fails and i get the same error as before. It gets up to 70% and stays there for a while before failing. I did press the "Record" button on the RC and made sure it was recording. HOWEVER, during the update, the mavic restarts which causes it to stop recording. Do I need press the "Record" button again when it restarts?
On a side note, I also cant get the No-Fly Zone Database Update to work. It gets to 60% and then stays there forever, without finishing. I left it at 60% for an hour before giving up.
To say trying update my aircraft is frustrating would be a big understatement...
2017-11-21
mcasa
Flight distance : 41427 ft
I also can not update my Mavic with error 0x020106. The remote control has been upgraded to version 1.4.0 while Mavic is version 1.3.550.
My account is: massimilianocasa@gmail.com.
Please add me to the beta program to be able to fly the Mavic again.
2017-11-23
DJI Susan
jake31 Posted at 2017-11-21 16:57
Generally, there is no need to press the record again during the update... please try several times to check whether it remains.
2017-11-24
DJI Susan
mcasa Posted at 2017-11-23 06:02
My account is: .
Received with thanks! I'll help you get the beta firmware and refer the above steps for refresh.
2017-11-24
jake31
DJI Susan Posted at 2017-11-24 03:06
I have tried doing countless updates over the past week and all have failed. I have used both the DJI GO 4 app and the Assistant 2. I have tried to update to all the different versions available, but again nothing has worked. I have followed your instructions with pressing record at the beginning of the update, but that hasn't helped.
My RC is currently at V1.04 while my air craft is at 1.03.0813. I have tried updating to all the versions available to me with the following results:
When trying to upgrade to V01.04.01 I always get an error through the update, which says "undefined 0x020106."
When trying to upgrade to V01.04 I always get an error through the update, which says "undefined 0x020106. Sometimes I also get error undefined 0x032800 if the update fails quickly in the beginning
When trying to upgrade to V01.03.10 I  get an error through the update which says "undefined 0x032800"
The amount of time I have spent on futile update attempts is ridiculous. Please provide me with a solution to get my drone flying again.
2017-11-27
DJI Susan
jake31 Posted at 2017-11-27 19:20
I'm sorry to the result, and afraid that we can not help you solve it in a long distance. Please send it in for fully diagnosis: http://www.dji.com/support The local team will take care of it after it arrived.
2017-11-28
sharkraph
Flight distance : 36650 ft
Hungary
Have same issue with upgrading
2017-12-8
DJI Susan
sharkraph Posted at 2017-12-8 12:15
Hey Sir, I've received your messages in PM. Just to verify, both the error code of 0x020106 and 0x032800 have been popped up during the update, right? The beta only fix the the error code 0x020106/0x020103, I'll help you get the beta and try first, it should be available in a working day later. If no helps, please offer the screenshot of error message and upgrade log for further assistance, thanks!
2017-12-10
sharkraph
Hungary
Thanks. Will check today. What is a number for beta build?
2017-12-11
sharkraph
Hungary
During upgrade to Beta 01.03.813 I have following errors:
When I try to downgrade to 01.03.350 I have following issues:
Also tried to make Factory reset and it failed as well
2017-12-11
sharkraph
Hungary
When I click Upload Error logs - it shows me Uploaded and then Error - need app to open Javascript.
2017-12-11
DJI Susan
sharkraph Posted at 2017-12-11 06:37
[view_image]
[view_image]
Thanks for getting back to us. I'm afraid that the issue can not be figured out remotely. Please start a case and send it in for further assistance: https://www.dji.com/support
2017-12-13
Rjrolyn
I encountered this when i first received my  Mavic, failed miserably on the app. So went to Dji Assistant app, same thing but the oldest trick in the book i disabled my Anti Virus program and  houston we have lift off - success. Used my Alienware laptop - Win 10 and disabled firewall . Hope you guys get sorted
2017-12-13
sharkraph
Hungary
DJI Susan Posted at 2017-12-13 19:27
You mean send mavic and RC for checking and fixing?
2017-12-14
M Stuart K
Flight distance : 1267717 ft
"mandatory update."
2017-12-14
DJI Susan
sharkraph Posted at 2017-12-14 06:14
Does the RC work well? If there is no other issue, I'd suggest to send the aircraft in only.
2017-12-15
boom_u_mad
Flight distance : 14154 ft
Hi, I'm also getting 0x020106 when updating.  Can I please have access to the beta?  My account is hubertd@gmail.com
2017-12-16
boom_u_mad
boom_u_mad Posted at 2017-12-16 14:59
By the way, my RC is already on latest version but the Mavic is still on V01.03.0400.
2017-12-16
DJI Susan
Hey there, I've received your message in PM, thanks! The beta is available in your account, please refer below and try again.
2017-12-17
mcmonkey
Thailand
DJI Susan Posted at 2017-12-17 23:56
Hi Any chance you can help me with this also.
I tried to update the firmware from 01.03.0400.
I have tried using DJI Go APP and the DJI Assistant. Both continually fail. I have tried manually. on the app and through cables, no cables, etc. (Pretty much everything!)
I am now in this position:
App 4.1.15 (I downgraded it from 4.1.18 on S7 to see if it would help, it didn't)
Aircraft 01.03.0400
Remote 01.04.0100
App DB 01.00.01.07
Basic Fly Safe DB 01.00.01.05
Please help me fix this issue! Thanks!
James
2017-12-20
sharkraph
Hungary
Good news. After weeks of unsuccessful tries I upgraded to latest 1.4.0100
Non firmware helped.
I asked my friend for old MacBook with USB port and after few tries of direct upgrade from 1.3.400 to 1.4.0100 with connected by USB cable and DJI Assistant 2 and connected and switched on RC with Android device on it, as well as clicking REC button when everything hangs - successfully upgraded.
Will check stability of flight later. But in Assistant and in DJI Go it shows 1.4.0100 everywhere.
Hope this lifehack help somebody.
2017-12-20
DJI Susan
mcmonkey Posted at 2017-12-20 03:01
Hi James, I've read your post as well. The beta will be available in your account soon, please check later.
https://forum.dji.com/thread-124828-1-1.html
2017-12-21
DJI Susan
sharkraph Posted at 2017-12-20 06:58
Thanks for sharing your experience here. Glad to know it works again. Enjoy it and happy flying!
2017-12-21
fansf63b15d9
Flight distance : 1637933 ft
I am having the same issue with my P4Pro.  None of the methods work and now I have no connection with the transmitter.  Using DJI assistant, it stops at 15% and show error  Can you please send me a beta to try account at markc@soaringvideo.com.au
2017-12-22
jooaljetta
Flight distance : 61719 ft
I have the same problem here. Can't update since V01.03.0550
Tried different sd-cards, cables, pc, mobile phones. My email adress is stefanthuir@gmx.de
2018-1-13
jooaljetta
jooaljetta Posted at 2018-1-13 06:11
Sorry, can somebody from the support help me?
2018-1-23
Ix Wasabi xI
Same problem please help
2018-1-24
nascimentohugo
Portugal
Same here!
Can i have the beta to see if it works
Thanks
2018-2-8
ToonDMS
Belgium
Hello, I have a firmware issue since few weeks which prevents me from using my AC.
When I try to update it, I got each time this error code: undefined 0x020106 I tried from DJI Assistant 2 and DJI Go 4 apps, with several batteries charged at 100%, without success each time. My AC is currently in V01.04.0300 firmware and RC has been downgraded in V01.04.0300.
My email address linked to DJI is antoinedewaele@gmail.com
Please help me!
Antoine
2018-2-15
ToonDMS
Belgium
Please help me!
Antoine
2018_02_14@14_48_43_upgrade.rar
874.94 KB, Down times: 4
2018-2-15
dad57
Hi All,
Have the same problem trying to update my V01.03.0400 to the latest
Could someone send me the V01.03.0813 on my account muller.messagerie@gmail.com
Many THX to all
2018-2-24
Alesiq
Brazil
I also can not update my Mavic with error 0x020106. The remote control has been upgraded to version 1.4.0 while Mavic is version 1.03.0400.
My account is: alessandrocomp@gmail.com.
Please add me to the beta program to be able to fly the Mavic.
2018-2-26
djiuser_UsPp8EDWAAud
I have the same issue as pretty much everyone else on the thread, my aircraft is on 1.03.0400 and my controller 1.4.0 and get an error 0x020106 error when updating.
I have tried contacting support by phone, online and email and no-one can help me.
My account is acmcg@outlook.com - please add me to the beta program
2018-3-1
DJI Susan
Hi all, the messages left here have been received, the beta will be available soon, please refer the 3# and update again. Thanks!
2018-3-2
12Next >
