Today I noticed that I did not sign up for all flights in flight records. I flew four times and the records have only two. Does anyone know the reason?
Is it possible that you did both times 2 flights with one battery?
Landed, but didnt switch the drone off?
Can it be, that flight1 is the first part of the logged flight 1,
and flight 3 is the first part of logged flight 2?
Just a thought
S-e-ven Posted at 2017-11-18 10:13
Each flight was on another battery. It may affect the order of inclusion of Spark, RC, Dji GO
DJI Elektra Posted at 2017-11-20 01:49
Did your app turn off during your flight? What is your model of device? You can try to find the log files in your phone.
Perhaps the app hangs. I chose active tracks when I wanted to go out and return to normal mode. Dji Go did not react. After a moment the application turned off. But I do not remember whether it was the first flight or the second one. (
Where to find logs?
My phone is LG G6
I will remove the application with the folder and re-check if it works correctly.
Krrisstoff Posted at 2017-11-20 02:26
Where to find logs?
If your drone disconnected with the app, there will be no flight log. Please connect your phone with PC and find the records. Here is the path: \DJI\dji.pilot.v4\FlightRecord.
