Punchbuggy
Flight distance : 483166 ft
You're not seeing the P4 icon as Assistant 2 has not detected that the craft is connected. If the craft is powered on, the USB cable is good and plugged into the micro-USB port on the craft properly, and the PC USB port is operational, then it must be the Assistant 2 installation.
If you're using a Win10 PC to run Assistant 2, you could also try to uninstall and then reinstall AFTER you've booted the PC into maintenance mode with Driver Signature Enforcement off. There's an unsigned driver which doesn't get properly installed otherwise, although from my experience that only affects proper operation of VPS calibration.
It's worth a try...
But Alabama is correct. The latest Win 10 update is preventing Assistant 2 from "transmitting" firmware to the craft now - it will connect to the craft, download the firmware selected, but not complete the update. I'm one of those who've reported it. Hopefully DJI will work out what's happening soon.
