Cetacean
Flight distance : 2528264 ft
Aloha Bracco,
This is my first time reading flight data, but your problem was for about 45 seconds, and it looks like you flew over an iron or magnetic structure of some sort. This happened over what looks like a road. Was there a wrecked vehicle of some sort there? Maybe you flew too close to a metal or magnetic source related to the road. Did you get to fly over that area again? Who knows, maybe you discovered a magnetite deposit!
After flying over that Magnetic Field Interference area, your Phantom jumped out of P-GPS mode and into ATTI mode. Then somehow, your ATTI Mode had an issue with the YAW axis and it generated a YAW Error.
Can you fly in a field somewhere and test your ATTI mode to see if you have a problem with your YAW function? Be sure there is not to much wind so control without GPS will be easier. Hopefully, the YAW Error was temporary due to whatever it was you flew over. If there is no YAW Error anymore, you may want to recalibrate your compass in a safe area without metal or magnetic interference.
Hope this helps!
Aloha and Drone On! |
