Inspire1Pro stuck in travel mode
2378 17 2017-11-19
donandamanda
Flight distance : 314173 ft
[size=14.666666984558105px]I have just had my Inspire1 returned from DJI following a control unit repair (thats what they told me was wrong anyway!)
[size=14.666666984558105px]It has come back with the following firmware installed:
[size=14.666666984558105px]Aircraft - 1.9.1.30
[size=14.666666984558105px]Controller - 1.7.80
[size=14.666666984558105px]The aircraft will not come out [size=14.666666984558105px]of travel mode.
[size=14.666666984558105px]I have tried to find an answer but nothing seems to work - downgrading the controller firmware, givin[size=14.666666984558105px]g th[size=14.666666984558105px]e screw a small turn with a screw driver in case it is stuck, moun[size=14.666666984558105px]ting the camera with the Inspire supported between two bo[size=14.666666984558105px]xes.
[size=14.666666984558105px]When I turn on the Inspire it reports in the app that it [size=14.666666984558105px]is not flight mode with the legs raised. I try putting it in to tra[size=14.666666984558105px]vel mode and then back to lowering the legs. None of this works[size=14.666666984558105px].
[size=14.666666984558105px]Is there any one out there that can help?
[size=14.666666984558105px]This is very urgent as we have a job next week so I do not have time to send it back to DJI again!!
2017-11-19
donandamanda
Not sure what happened to the post - I hope you can read it ok
2017-11-19
donandamanda
I have just had my Inspire1 returned from DJI following a control unit repair (thats what they told me was wrong anyway!) It has come back with the following firmware installed:
Aircraft - 1.9.1.30
Controller - 1.7.80  The aircraft will not come out of travel mode.
I have tried to find an answer but nothing seems to work - downgrading the controller firmware, giving the screw a small turn with a screw driver in case it is stuck, mounting the camera with the Inspire supported between two boxes.  When I turn on the Inspire it reports in the app that it is not flight mode with the legs raised. I try putting it in to travel mode and then back to lowering the legs. None of this works.
Is there any one out there that can help?  This is very urgent as we have a job next week so I do not have time to send it back to DJI again!!
2017-11-19
TruGreen
Flight distance : 621909 ft
first thing i would do is try to upgrade the RC firmware so it matches the AC, then rebind the RC to the AC heres a video that shows how to bind
2017-11-19
donandamanda
TruGreen Posted at 2017-11-19 07:51
https://www.youtube.com/watch?v=kkynWM0Wh2U
Thanks for that video - however the controller is linked as I can operate the gimbal with the slave remote controller.  It is just the travel mode function that is not working!!
2017-11-19
TruGreen
try to get the RC firmware to match the AC, also check the plug for the center frame its possible it came loose during shipping. the plug is on the same side of the craft as the red button but in the back behind the landing leg where the battery goes into
2017-11-19
donandamanda
TruGreen Posted at 2017-11-19 09:13
I have checked the cables and all seem secure.
I see the latest firmware offered on the controller is 1.8.   However due to the reason the Inspire went back to DJI in the first place (updated firmware and Inspire kept loosing control) I am reluctant to also go to 1.10 or 1.11 on the aircraft - a few forum posts saying that the video feed breaks on 1.11.
Should I go to 1.8 on the controller?
2017-11-19
Daroga
Flight distance : 3517287 ft
donandamanda Posted at 2017-11-19 09:33
Sorry Don,
Mindy is correct, the matching RC firmware for the returned aircraft is actually v1.7.60  and your RC is on the latest firmware version 1.7.80 which states that it will not downgrade. Please ignore my PM as it is also incorrect....
Disregard the below as it is incorrect--->
Your Aircraft is on 1. 9.1.30 and can only be downgraded to v1.8.1.00 or later. That's because in v1.8.1.00, DJI changed the encryption between the RC and the aircraft. Here's the Release Notes for 1.8.1.00:
2016.04.07
1. Firmware upgraded to v1.8.1.00
2. DJI GO Android upgraded to v2.7.2
Major Updates
1. Improved encryption to enhance security during transmission. Both the aircraft and the remote controller must be upgraded or else they will not link.
2. Fixed the issue of landing gears lowering in midair on rare occasions.
3. Improved stability for camera.
4. Optimized gimbal parameters.
Notes:  Be sure to upgrade the aircraft before upgrading the remote controller, otherwise the aircraft may not able to exit Transport mode properly.  
Battery firmware is included in this All-in-One firmware update. Update all Intelligent Flight Batteries by using this firmware.   Camera version v1.8.1.00 and aircraft version v1.8.1.00 should be displayed in DJI GO. The version will only display correctly in DJI GO after connecting to the Internet when upgrade is complete.
So if your controller is back at v1.7.80, then the encryption is diferent between the aircraft and RC and they can't communicate correctly. You will need to upgrade the RC to at least 1.8.1.00 or later...
You can get v1.8.1.00 for the I1Pro here-> Click here to download DJI firmware...
2017-11-19
Daroga Posted at 2017-11-19 18:20
2016.04.07
Hi, Daroga, thanks for the input but I don't think downgrading firmware of aircraft would solve the problem.
There are two ways now: 1. Updating the firmware of aircraft, but the aircraft must exit travel mode firstly.
2. Downgrade RC to V1.7.6, unfortunately, the new firmware cannot be downgraded according to release notes.
The firmware version of aircraft and RC is not synced.
2017-11-20
donandamanda
DJI Mindy Posted at 2017-11-20 01:28
So can you advise DJI Mindy what I should do.  Should I upgrade the controller to 1.8 (is this available?)
Thanks
2017-11-20
Donandamanda, we are so sorry for the trouble that has been caused after repair, unfortunately, the aircraft still needs to be sent in for repair, since the firmware of aircraft and RC does not match, downgrading RC and updating aircraft cannot be done by yourself at the moment.
If you have friends who have RC which the firmware is V1.7.6, it would be great.
We apologize for the unpleasant experience, we would learn from this and keep improving repair quality.
2017-11-20
donandamanda
DJI Mindy Posted at 2017-11-20 01:36
Are you kidding me.  Is that the only solution?
What if I can find someone with a remote controller at 1.7.6.  what process would I have to follow?
Will that controller link to my Inspire to get it out of travel mode?
2017-11-20
donandamanda
donandamanda Posted at 2017-11-20 02:08
I should also ask is it possible for me to hand carry the Inspire to your authorised repair centre here in the UK to get them to fix free of charge.
I need the drone for a job on Thursday this week so this is disasterous news!!
2017-11-20
donandamanda Posted at 2017-11-20 02:15
We are so sorry that there is no official repair center in UK, if you don't have time to send in, please try to contact retail repair center in advance to see if they can assist, but we are unable to force them to get it addressed for your without any charge. Thanks for the undertanding.
We sincerely apologize for this situation.
2017-11-20
Donnie *
Flight distance : 3636782 ft
Try Daroga idea ( post 8 ) the man is a genius and that is your only hope.
edit : ( Sorry , wont work < please disregard )
donnie
2017-11-20
Daroga
Please disregard my entire PM as it won't work either.
Have you tried manually lowering the gear completely with a screw driver, attaching the camera and upgrading to 1.11.1.50?
2017-11-20
If you could find a RC which firmware is V1.7.6 or V1.7.4, you just need to bind the RC to your aircraft to make it exit travel mode. Then update the aircraft to the latest version, everything would work.
2017-11-21
Donnie *
Daroga Posted at 2017-11-20 17:36
Now you tell me!!!! LOL
donnie
2017-11-21
