BagoDJIoperator
Flight distance : 1077608 ft
hallmark007 Posted at 2017-11-19 07:25
The first thing I would ask is how high you were flying , if it was low I.e. within a couple of metres altitude VPs could be a problem 1 if light is not sufficient 2 if the ground is not textured enough for VPs to lock so causing aircraft to move.
If this is not the case it could be you need to try an IMU calibration , you could also do VPS calibration if you think that might be a problem.
Thanks for the quick reply, I will try a VPS calibration, I flying over my wooden deck, I was flying about 10-30ft above ground. I try and do an IMU calibration later since I have big event to cover with my drone. |
