Lord Beowulf
DJI Diana Posted at 2018-5-27 22:56
Hi Beo, I'm sorry to hear about the issue that you are experiencing. The bin file has been sent to you via PM, please go to check it. Thanks.
Hi Diana:
Thanks. The new firmware helps, but isn't a solid fix. I was able to launch fine the first time after the update, and after shooting video on my land for 5-10 minutes, brought it back, swapped batteries, and attempted to run a waypoint mission I fly regularly to survey my land. I was able to take off and land, but couldn't get it to accept the waypoint mission. I noticed one of the error messages was related to the range limit, and I recalled that I had problems after the last firmware upgrade where even though range limit was disabled, it was still applying. So I went into DJI Go and toggled the range limit on and off, but then when I tried to fly again, I was back to the ESC status error.
I gave up at that point but came back later to see if the range limit was the culprit and ended up being able to run the mission. However, when I brought the drone back afterwards to swap batteries and run another waypoint mission, I was back to the ESC status error again, and rebooting repeatedly wouldn't resolve it.
This is understandably frustrating. Does DJI have any idea what's happening to these drones and how to resolve it permanently? Given the number of times I had to send it in when I first got it just to get a 4K camera that would reliably record 4K video, and the limited number of total hours on this drone, it's pretty disappointing to not be able to use it when I need to take pictures.
Thanks,
Beo |
