Vendex
Flight distance : 13426122 ft
Bulgaria
Punchbuggy Posted at 2017-11-28 15:50
Correct - the unsigned driver issue has typically only affected VPS calibration. The "Transmitting..." issue is new.
If you reboot your PC with driver signature enforcement off and reinstall Assistant 2, you'll be prompted as to whether you want to install the unsigned driver. Say Yes, and it'll install the driver - otherwise it will silently skip over the driver and continue the installation.
That's absolutely correct, thank you Punchbuggy. Looks like we'll wait for the next version which fixes this issue |
