skyguy17
Flight distance : 190745 ft
An FYI to anyone new reading this thread due to RC issues
Here is how I solved this issue:-
1) Install DJI GO 3 app from Apps store, launch app (at this time P4 is off until I say)
2) Select P3 Pro as aircraft (SE and Standard are wifi, not sure if this would make a difference), using the 3 dashes at the top right of the app press and hold for 10s or so. A new screen appears showing suggested current firmware of RC. Scroll down to firmware 1.6.0 select "Firmware Refresh". Wait for it to install then close the app and shut off RC.
3) Reboot RC, after a new minutes on shut off RC (not sure if this is really required, but it seemed right)
4) Open up DJI GO 3, Select P3 Pro and press camera (have the lightning cable connected to RC and iPad/iPhone). I had over 50% charge on my RC (btw)
5) Once in main screen with telemetry info wait a few minutes and press the Left upper area just next to the DJI logo saying "No xxxxxx connected " in red, this will take you to the Aircraft setup screen.
6) There you will see a warning message triangle, press this area and it suggests upgrading the firmware as you have 1.6.0 installed and the latest is 1.9.3
7) This started the firmware download and then with lots of beeps and blue flashing light the upgrade was a success !!!!!
8) On completion it will tell you to reboot the RC. At the same time I closed off the DJ GO 3 app.
9) Reboot the RC again. Mine complained at low battery so I did a second reboot and 3 white LED battery level lights came up as well as the RED LED indicating no aircraft bound.
10) Turned on P4 and launched DJI GO 4 app and BANG.... full signals on RC and Video feeds and NO flashing red/green led any more just solid green. So fingers crossed for her maiden flight tomorrow ( double fingers crossed)
I hope this helps others; note the DJI GO 4 apps does the same if you hold the 3 dashed lines for 10s or more. I did not try this route to roll back the firmware on the RC. |
