Can anyone tell me about the Gimbal anti vibration pins and rubbers: when should they be changed and also should there be four pins/rubbers or two?. Their are only two fitted at the moment and that's how many it had when i bought the phantom 3 pro.
Rubbers change when any split or get damaged. There is no life term for them.
Pins (these are Anti-Drop Pins) and only two are usually fitted ... it is not necessary to fit 4. These also have no term life and only replaced if damaged ..
Thank for the info Nigel. I keep checking when I use the drone and I'll leave until they need replacing and I'll leave only two on.
