Punchbuggy
Flight distance : 483166 ft
When you say "not loading", do you mean that you click on the Calibrate button but it wont start? It's just greyed out?
If so, uninstall Assistant 2, reboot your PC into maintenance mode (click <Shift> + Restart, and select that mode), and when restarting select option #7 to Disable Driver Signature Enforcement. Then reinstall Assistant 2, and when it installs device drivers in the DOS box (the black window) you will be prompted whether you want to install some drivers - say Yes each time.
Then don't reboot, and run Assistant 2 as Administrator (right click the desktop icon and then the option).
There are a couple of drivers which otherwise silently don't install properly as they lack a digital signature. One is the Vision driver which communicates between craft and Assistant when doing the Calibration. |
