Labroides
Flight distance : 9991457 ft
Anokadrone Posted at 2017-11-22 04:29
I am not quite following you. Are you saying that there is an altimeter reading on the main screen? If so, I will find it but I did not see it the last time I flew. Also, if there is a reading, the altitude above home point would be be just fine since the FAA reg is stated in as 400' AGL (above ground level)
Thanks all
Look at the bottom of the screen.
See the numbers there?
The one with a large D is Distance away
And the one with a big H is Height (above home point)
Next time you fly, watch the numbers and see how they change. |
