Malakai_UK
Flight distance : 536115 ft
My workflow has a cost, but luckily I work in education so get access to the software for free.
Import pano images to lightroom for processing (little bit of colour adjustment, levels, sharpness etc) export to working folder
Import processed images into autopano giga checking horizon levels etc and either output as a little planet.
If I just want a quick image for social media I also use DJI Go to stitch and then use Theta to make the output images/video.
I have to admit, the spark being able to capture panoramas is a great thing but it really need to use bracketed shots or at the minimum HDR for each image, i find sometimes it will either blow the sky or underexpose the ground.
One hint I can give you is to take a photo of the sky while your spark is up there if you can. If not then use the spark pointed upwards. You can use this sky image to help fill the top of your pano later. I use my go-pro with its widest view to grab a shot. |
