C&A I.A
Flight distance : 312579 ft
Brazil
Diana, I have news. I had a breakthrough here with my P3A. I'll try to explain as simply as possible because of the translation. (to remind my drone is not in warranty) On Saturday 25th, I was unhappy with the results I was having decided to disassemble some parts of my P3A and you do not know what I discovered !! when dismounting the support of the "vision positioning" I noticed that the electronic plates that are inside this support were leaning against each other, causing that the aircraft did not initiate the link for pairing with the control. I loosened the screws and it was immediate .. the link light came on and the pairing with the RC was done at the same time as magic. I was lucky that nothing burned, because there is a sign on the overheating plates. I do not know why these boards were leaning against each other, I think moisture combined with heat eventually swelled these electronic boards. Now I had another problem. When checking the firmware installed through the DJIGO application I noticed that the downgrade attempts I made had some efficiency .. I forced downgrade to one of the first versions, version 1.9.3 that ended up getting 1.1.9+, and now the memory card reader no longer recognizes the * .bin. Firmware .. reminding that the memory card is recognized by the gimbal .. but he does not read or record anything. It does not create logs, it does not update .. when I turned on the drone I also noticed that the locolized LED on the gimbal flashes twice and goes out completely .. and if I leave without a card there the LED blinks incessantly in red. I am now looking for an advanced way to re-upgrade my aircraft. Please help me. If there is any doubt in my answer I ask you to inform me the section where it was confused so that I can translate again .. |
