DJI Elektra
I think your drone is P3S /P3SE or P3 since P3P is connected with USB cable.
P3S /P3SE:
If you want to reset wifi, please turn on the remote controller and then turn the gimbal dial to the far right, toggle the S2 switch back and forth for at least three times. You will hear a beep if it reset successfully. The default password is 12341234.
P3:
please hold down the C1 and C2 buttons on the back of the remote controller, press and hold the camera settings dial until you hear a beep. Immediately toggle the flight mode switch. You will see the status indicator will blink red and green alternately.
Hope it can help.
