Noob question about the charging hub in the Spark fly more pack
920 5 2017-11-23
Chairman
Flight distance : 63438 ft
New Zealand
I've tried google, and youtube, and forum searches, but if there is a relevant answer out there it's buried in hundreds of more ordinary questions. I even tried reading the manual !
On the charging hub there's the port at one end where you plug the power lead in, on the opposite end there's a rubber cover and underneath that is a micro usb port. What's the usb port for ? It's not even shown in the manual. The input voltage for the hub is more or less the same as car cigaratte lighter voltage, can I plug a usb cable into the usb port and charge batteries in my car while I drive ?
Thanks
G.
2017-11-23
Wachtberger
Flight distance : 261509 ft
The micro USB port is only for potential firmware updates of the charging hub. You can't do anything else with it.
2017-11-23
Chairman
New Zealand
Wachtberger Posted at 2017-11-23 05:28
Nuts, I'll have to wait until the portable charging station is on the shelves.
Thank you
2017-11-23
Viking-Pilot
Flight distance : 2379249 ft
No you can not, that port is for firm ware update, I have had the same thought at the beginning but I had to buy me a power converter for the car, so now I can use the charging hub and charge 3 batteries at the time while i'm on the go.
2017-11-23
S-e-ven
Flight distance : 5922034 ft
Thailand
For a car you better get a voltage converter. Inexpensive, easy and quick to get.
2017-11-23
DJI Thor
Flight distance : 13602 ft
Please refer to Wachtberger's answer, it is for updating the charging hub's firmware.
2017-11-25
