SD card not formatting
6674 19 2017-11-24
Braydoh
Hey im trying to format a new sd card but it wont work on the app (says failed everytime), and when i connect the drone to the computer it doesnt show up the SD card and the drone just beeps?? please help im starting to get annoyed. Its a new SD card.
2017-11-24
ALABAMA
Flight distance : 10442687 ft
What is brand and size of card?
2017-11-24
Braydoh
Toshiba 64gb
2017-11-24
Geebax
It sounds like you are not connected to the aircraft?
2017-11-24
repairman
Flight distance : 16581 ft
you are connecting the drone to the computer.i have never formated a sd card this way.its done through the app .
2017-11-24
AlanHd
Flight distance : 797365 ft
Have you tried format the card in the computer.
2017-11-24
cazz007
Flight distance : 70184 ft
having same issues, just stopped during taking pano, not working since.  i formatted it on compu put it in aircraft and same thing sd error
2017-11-25
Geebax
cazz007 Posted at 2017-11-25 00:24
Then it is a pretty good bet that the SD card is not fast enough. Try a Sandisk Extreme card.
2017-11-25
RedHotPoker
Flight distance : 165105 ft
Geebax Posted at 2017-11-25 00:31
Have you tried to format the micro sd card, through the app.
There are two places in the app, to do this.
RedHotPoker
2017-11-25
Braydoh
Yeah I’ve tried all ways I’ve read online. It’s a class 10 card with 90 bits per second. I’ll try another brand.
2017-11-25
sky wombat
Flight distance : 1454078 ft
So when you put the SD card in the computer it doesn't show in the root directory? At a guess I'd say it sounds like a dud but you could try formatting the card in another device such as camera, dash cam etc. that should confirm card at least formats. Then try wiping the card, re-insert etc and hopefully all should be good. If all else fails get a couple of 32Gb and try them. Extra cards won't go astray. As Geebax suggest SanDisk are reliable.
2017-11-25
KedDK
Flight distance : 1133038 ft
Denmark
If the computer or card reader is a little outdated you might not be able to read a modern high spec card.
If I was in your shoes I'd try a newer external reader.
2017-11-25
cazz007
itdoes
both my sd cards are bad. they worked before latest firmware update. i had a 32gm sd card in my fire tablet i was not using so i tried it and it worked. it does say slow speed
2017-11-25
Geebax
cazz007 Posted at 2017-11-25 14:50
Then it very well may not work if you record say, 4K at 60 fps.
2017-11-25
AFAV8R
Flight distance : 2306 ft
Just reported the same issue. I'd love to hear what you find out. I've tried SanDisk Extreme 128G, SanDisk Extreme 64G, and SanDisk Extreme 32G. All with the same results you've been experiencing.
2017-11-25
Braydoh
Nothing i try seems to work it’s very frustrating. Sent the 64gb cards back and goin to try buy another brand. It’s just annoying been some great autumn light nights that I’ve wanted to capture and I can’t!!!!!
2017-11-26
ALABAMA
Nothing about the sd card should causing a beep
2017-11-26
Hellsgate
Flight distance : 1991555 ft
I have had similar problems it turned out to be a faulty sd card
2017-11-26
Geebax
Braydoh Posted at 2017-11-26 08:00
Why not use the SD card that came with the Phantom?
2017-11-26
DesertSweeper
Flight distance : 344 ft
United Arab Emirates
My Mini just point-blank refuses to format ANY card. I can get them to format in my Mavic no problem. The mini has NEVER worked from day one. If I experience recording issues with the mini I pop the card out, format it in the Mavic and return it to the mini and all is good again (for a while).
2020-10-21
