Video recording and feed cut out
556 7 2017-11-25
MuskokaDan
Flight distance : 6224 ft
Hello: was flying today and recorded my first few videos fine at 120m. Was flying down a path at like 3m and my screen started going pink and black and static like. This was actually recorded too. Any ideas?? Screen capture from recorded video attached. Tks
2017-11-25
peorge9566
Flight distance : 19547 ft
Send it back!
2017-11-25
TruGreen
Flight distance : 621909 ft
what device are you using? is everything  up to date
2017-11-25
Jenee 2
Flight distance : 7852129 ft
Check the sd card and see if the video is ok there. There has been a known problem with some recent versions of the DJI GO 4 app for android. What phone/tablet are you using? What firmware version is in the Mavic and RC and what version of the app are you using?
2017-11-25
dronist
Dude, never seen this pinky color before!
Mostly green! but hey in Canada anything can happen.
Post an actual video,  also let us know if you play the video on the computer does it have the same pinky colors? If yes then send it in, if no then delete the GO4 app, reinstall and run it again. This is not a long range transmission issue but curious to see if it is happening all the time or periodically. Good luck dude!
2017-11-25
Feiky
Flight distance : 932717 ft
Having similar issues since the upgrade. Down under, I get the full suite of effects......green, pink and parts of image.
2017-11-25
Feiky
2017-11-25
Feiky
2017-11-25
