Adding an FPV Camera?
654 1 2017-11-25
MrPinaColada
Flight distance : 790082 ft
I've got the transmitter and reciever for an fpv camera setup. Ive been curious about adding one since I do a lot of backwards flying for subjects, and this would help me keep an eye on whats going on behind the phantom when it's flying backwards. Anyone try this setup before? Isnt transmission sent through 2.4ghz and 5.8ghz? Im assuming Id need a different frequency for an fpv camera.
2017-11-25
Cetacean
Flight distance : 2528264 ft
Aloha Pina,
     This all depends on which Phantom you plan on using.  The P3S uses both 2.4 and 5.8, the P4 uses only 2.4 (if I remember right).
     One thing you can try is to set up a "rough-out" system with your custom FPV camera set up along side your Phantom.  Turn everything on and see if everything works right and if there is any interference.  If it works, and there is no interference, go to step 2.
Aloha and Drone On!
2017-11-26
