How to hard reset Phantom3 Advanced controller?
23937 9 2017-11-26
Joey1234
Thailand
My Phantom3 Advance's controller was force upgrade by system but after success upgrade it turns off themselves and cannot turn on.
Is this problem come from DJI incomplete controller firmware version? Can we do a hard reset to solve this problem? How can we reset it?
2017-11-26
DJI Susan
Is there any reaction when you plug in the original charger? As far as I know, we do not release any mandatory update for Phantom series in United States...
2017-11-26
Klimshuck
Flight distance : 53241 ft
Hi
i have the same Problem !
No reaction when plug in the orginal charger !
2017-11-27
Klimshuck
Hi Joey1234
i found this in a German Forum-> "to RC Reset"
Press C1 +C2 + the right scroll Button + Record Button and than push the Power Button
sorry my English is so Bad °_°
auf Deutsch/ in German
Die Tasten C1 + C2 + Drehrad + Aufnahmeknopf gedrückt halten und die Fernsteuerung einschalten einschalten.
Hier nochmal ausführlich:
1. DJI app muss als Standard App installiert sein!
2. Kopter aus.
3. Funke aus
4. C1-C2-Aufnahmeknopf- und rechten Drehknopf gedrückt halten!
5. Mit irgendeinem freien Finger die Funke einschalten, die 4 Knöpfe nicht loslassen bis die DJI App automatisch gestartet ist.
I can check it in 3Hours / I`m at Work ;-)
mfg Klim
2017-11-28
Klimshuck
is working ! ! !
"google translate"
Here again in detail:
1. DJI app must be installed as a standard app!
2. Copter off.
3. RC off
4. Press and hold the C1+C2 + record button and scroll-wheel!
5. Turn on the spark with any free finger, do not release the 4 buttons until the DJI app is started automatically.
My RC Model: GL330C
mfg Klim
2017-11-28
fans688fb282
Flight distance : 437411 ft
I see excuse after excuse from DJI on their Phantom series. I called and talked online with two different help personnel and they told me to do two different things. I was getting a sensor error so imu calibration fixed that.  Once fixed drone is fine. Then a new error says remote contrgoing to a controller air. Here's the issue the Phantom is an albatross it's an old product it's not being supported too much anymore as they move into their mavic and smaller drone. It's okay to say some problems cannot be fixed on the Phantom. I IMU calibrated, then remote contoller says errors.I have calibrated the remote control. And once I fix one problem another one comes up. You can count on DJI charging you 300 more dollars for fixing something. The Drone ain't even worth that much now. I've had the Phantom 3 advanced for a couple of years now and it worked great at the beginning. Here's what I know The Phantom series will continue to break down. Go to mavic or Spark
2019-2-23
Philbo
fans688fb282 Posted at 2019-2-23 06:33
Yeah, buy another DJI drone, that'll show 'em!
2022-6-22
djiuser_X5v6X03UOQWb
Flight distance : 2855299 ft
Philbo Posted at 2022-6-22 15:36
my exact thoughts
2023-5-15
djiuser_XPvCm8x4rTr8
I got a new controller for my DJ Phantom 3 professional how do I reset the controller to the unit what should I do to make it work without the app please let me know thank you
2024-10-21
DJI Wanda
djiuser_XPvCm8x4rTr8 Posted at 10-21 01:19
Hi, there
Regarding link tthe remote controller to the Phantom 3 pro, you can see the video for instruction:
2024-10-27
