Bekaru Tree
Flight distance : 15513100 ft
South Africa
Min safe temp is 0 degrees/32 F. -10 degrees C is a significant amount lower. i'd think that risk of losing yr drone is pretty high and if any extra unanticipated other thing should occur (wind etc) then i would be surprised if you do not end up losing yr drone. Yr battery life potential will also be less - rather get it back too soon than too late. I think you are nuts to try but let us know if it worked out for you. at -10 i'd think you at high risk to lose yr drone and do not recomend you try unless there is a life saving situation at play - if the wind picks up, pack it away. lastly, if you absolutely must do this flight, then perhaps use yr first battery to do an short test run within VLOS to see battery performance and get an idea of how far you can fly in those temperatures. i get about 17min per battery in proper temp conditions in sport mode with a round trip distance of about 5- 7km per battery. You should not expect to be able to fly the advertised 27minutes - i suggest....do'nt do it - but good luck if you do. |
