Phantom 3 Pro
MODEL: W323A
Firmware update version 1.11.20
When I try to install new version 1.11.20 I get this code; however when conntected to remote it shows Overall Status - Normal (Latest Firmware). Everything works as should but no video signal. And there is a No Image Transmission Signal error. Please advise!
Delete history success.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:15 remo-con disconnect======
Packet: P3X_FW_V01.11.0020.bin
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
========== 2017.11.26 10:11:04 =====================
Result: Failed.
========== 2017.11.26 10:13:57 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Olá eu tenho o mesmo problema e estou desesperado para corrigir o problema também preciso ajuda do mesmo erro, agradecida alguma resposta para corrigir o problema, meu email filipemoreira36@gmail.com
SHOODY Posted at 2017-11-26 16:28
reinstalled a new downloaded copy and still get "Failed" result. Also tried to install version 1.10.0090, it "Failed" as well.
Did you follow the directions in the video below from DJI?
The latest v1.11.20 firmware does not support to refresh or downgrade. If you have got the latest aircraft and RC firmware, please try to link RC. Also, please make sure the pins on the side of gimbal is well seated.
