FAQs for DJI Goggles RE
12
20486 64 2017-11-26
fans82ce4f1f
How can I purchase DJI Racing Goggles in Australia now please?
2017-12-30
eirikso
Norway
I got my Goggles RE today and are doing som testing with my existing analog FPV equipment. I have systems with both PAL and NTSC cameras. So far it seems like my goggles ONLY support PAL for the analog signal (I bought them in Norway). This seems strange. Both my fatsharks and even my dead cheap eachine goggles seamlessly switch between PAL and NTSC.
Is this something that can be fixed through a firmware update? It is really annoying that some of my equipment won't work because it is NTSC.
2018-1-6
UNsyncED
Flight distance : 1083392 ft
fans82ce4f1f Posted at 2017-12-30 22:16
https://www.d1store.com.au/ Seem to have stock.  I purchased a pair from them.
2018-1-7
Sjd666 1
Flight distance : 3785020 ft
Can someone tell me the difference between the 2 Pagoda antennas you get with the goggles, are there any differences between the 2 ?
Cheers
2018-1-8
PRGeno
Sjd666 1 Posted at 2018-1-8 16:23
Cheers
I don't believe there is any difference at all.  I believe they are exactly the same but I assume since DJI uses a less common LHCP antenna they provided a second one, along with an adapter for the less commonly used RP-SMA Female connector on their antennas for use on your FPV models.
Personally I would have preferred they provided an RP-SMA Female to SMA Female adapter (which has proven to be pretty hard to find) to allow the easy use of commonly available RHCP antennas on the goggles instead.
2018-1-9
Sjd666 1
PRGeno Posted at 2018-1-9 14:46
Hi PRGeno
Thanks for the info, just seemed strange that they would supply 2.
Cheers
2018-1-10
djsomi
Hungary
Hi,
Is is possible to hear sound on analog mode? I was not able to hear anything from my racing drone.
Many Thanks
Zoltan
2018-1-12
DJI Grace
Flight distance : 405039 ft
djsomi Posted at 2018-1-12 08:08
Hi,
hey
sorry that it is not possible to hear sound on analog mode.
2018-1-14
Wilhelm.dutoit
Namibia
DroneRacer101 Posted at 2017-12-27 10:23
I would be happy to help, but it's really difficult to sort out what you are trying to do.  I think you are confusing and combing several features of the goggles.
Diversity switching in FPV generally refers to multiple receiving antenna on your goggles for analog video transmissions.  These goggles have a single receive antenna.  Be default this is a left hand polarized pagoda antenna but that should not be difficult to change.  This however has nothing to do with the Ocusync Air module.
Hi DroneR 101,
I have a question: Im looking to build a TBS caipirinha v2 long range HD fpv wing with option 2.
1. On the goggles there is no point in upgrading the pagoda because its 5.8 and im using the ocusync feed right?
2. On the air unit can i connect the following and will it make a difference to get better range and have better mounting options?
https://www.amazon.com/dp/B01H15 ... 1WXHTHBVR&psc=0
https://www.getfpv.com/fpv/anten ... de-antenna-set.html
2018-1-16
csamaniego
Flight distance : 497438 ft
Chile
Hi, how can I have a video output of the hd signal (ocusync air unit) from Gogles RE?
I want someone to see the images on a television.
Thanks,
2018-2-3
fans49243b5a
Flight distance : 185262 ft
Hi Grace,
i bought and activated Ocusync Air Unit in the USA (FCC-Mode i asume). Now i'm back in Europe - how can i swith the Air unit to CE-Mode to fly legally?
2018-2-4
DJI Grace
fans49243b5a Posted at 2018-2-4 02:47
Hi Grace,
Could you start a new thread for this question? In that case, many other users will share their best methods for you and I can pass your thread to my colleague.
2018-2-4
fans49243b5a
Thanks Grace
i did so
2018-2-5
thomas.chan
Flight distance : 495784 ft
Does the coach mode work with DJI OcuSync Air Unit , pls?  And I can get HDMI Video out from the Remote control?
2018-2-6
fans49243b5a
thomas.chan Posted at 2018-2-6 06:33
I think it is not possible to link any of the DJI Controllers with the air unit.
But it would be great if you could link Mavik/Spark/Mavic Air controller with the GooglesRE to controll the air unit
2018-2-6
Huskers
I’m excited to get my RE goggles on Monday. Have a few questions about them as they’ll be my first DJI goggles. I have a Mavic Pro and a few other personal quads. All my quads have RHCP antennas yet I see the DJI goggles have a LHCP pagoda antenna.
1. Is the pagoda only for analog reception, like that being transmitted from my non DJI drones?
2. Is it ok to use a RHCP antenna on the DJI goggles instead?
3. If the answer to #2 is NO, then am I correct in assuming I’d need to change all my other drone antennas to LHCP?
Thank you, Alex
2018-2-8
Wilhelm.dutoit
Namibia
Huskers Posted at 2018-2-8 22:24
1. Yes. Although in ocusync mode both 2.4 and 5.g8 is used.
2. Ye.
2018-2-21
djiuser_01KnycX3ZLtg
Flight distance : 24167 ft
theself Posted at 2017-11-27 14:02
Do the racing edition goggles have an HDMI input for other video feeds such as the connex prosight HD system for racing drones? Thank you
HDMI latency test of DJI goggles
2018-2-27
LFIELD
I'm using The DJI RE Goggles with a Mavic pro.  I bind the the Mavic with the Goggles and everything is fine.  However, when I turn things off between flights, I have to rebind again to fly again.  Is there anyway to preserve the bind for a day of flying?...Larry
2018-3-7
Jamesjts
Flight distance : 916578 ft
DJI shows a boat using the Goggles RE but there is no indication of if the Occusync transmitter and camera are being used. Is the Occusync transmitter and camera water proof or water resistant and if so to what extents?
2018-3-16
djiuser_NjBecQMOUosd
Is it possible to record the video from the Goggles RE to the SD Card in the goggles?  Is this also possible when the input to the goggles is via HDMI?  Would like an easy way to record the video from my CONNEX while flying.
2018-3-21
fans2fe5a996
Flight distance : 32034 ft
Hi,
voting for this as for a feature request. My analog VTX is sending both video and sound track. It is crucial for me to hear motors and low battery warning beeps in headphones while racing.
2018-4-8
djiuser_r9rm60q2kMUQ
Flight distance : 61936 ft
About the Goggles RE:
    4. Goggles RE supports analog transmission at any integer frequency between 5.650~5.925 GHz and analog video storage on a Micro SD card.
How do I record analog video to a Micro SD card? In the digital mode, I see a menu option to start recording, but I don't see anything in the menus for analog.
2018-4-11
fans2fe5a996
djiuser_r9rm60q2kMUQ Posted at 2018-4-11 10:38
push the Fn button on bottom side of the goggles to start recording.
2018-4-12
HVMediaUG
Flight distance : 1958169 ft
Dear Community,
is it possible to use the Air Unit as a FPV Cam for my S1000+ and feed it with iOSD mini/A2 flight data?
The S1000+ is powered by S6 LiPo. I have a CAN-HUB with several free sockets.
We dont want to use the remote-control functions of the ocusync system since we have the a2 inbuild system running with a futaba t14sg
With kind regards
hvmedia
2018-12-21
12
