CuaC
Flight distance : 369626 ft
Hi all,
as many of you know if you want to get the super smooth cinematic-like gimbal movements you need to have a very slow sensitivity on your gimbal and sticks to be able to define properly the movement on your shot. However, when you set it up to behave properly for your shots, then it's terribly slow for other movements: You try to move to another starting position, or quickly pan around to see obstacles or find the proper alignment and you just start suffering from the slow movement that you set up for the shot itself.
If we could define different profiles and quickly switch from one to another by pressing a button we would have the best of both worlds: fast response when needed and the cinematic setting for the shots themselves.
Wouldn't you like to have something like this?
