CrystalSky Screen Protector
1719 10 2017-11-27
fans7a394749
Most of us take great care of our investments, but incidents still happen. So, I had a custom-size screen protector ordered through Bodyguardz. As you can see from the photo (installed) that the width isn't a complete area cover. I could've gone 2mm wider. The actual dimensions I went with is 118mmx67mm. For complete screen coverage, you'd go with 120mm width.
2017-11-27
DJI Elektra
Hi, sir. The size is  compatible. Hope it will protect your crystal sky well.
2017-12-2
fansede6f1f8
Flight distance : 849183 ft
Thanks for the info, Im in the UK and have just ordered one as I couldn't find one over here.
2017-12-3
TomWolves
Flight distance : 110577 ft
So what is the actual size I would need to order for a CrystalSky 5.5 monitor? I just bought a CS 5.5 and wanted to get a screen protector, but couldn't find one. I noticed you put 120mm width, but what length?
would I want a 122mm X 69mm, or 122mm X 67mm ? thank you for your help. Does DJI recommend these for the CyrstalSky Monitors?
2018-1-7
A CW
Flight distance : 13926112 ft
Does this effect the brightness/reflection on the screen?
2018-1-7
reygun1
TomWolves Posted at 2018-1-7 13:18
you'd order 120mm x 67mm. I've not seen an official recommendation from DJI. Whether DJI chimes in or not, this has been working very well for my use -- with the Mavic, Osmo+ and OSMO Raw.
2018-1-8
reygun1
A CW Posted at 2018-1-7 13:27
I haven't noticed any effect on the brightness or any reflection
2018-1-8
A CW
That’s good to know - thanks
2018-1-8
Tviscomi
Flight distance : 106886 ft
I would be more concerned as to whether or not it affects the screen sensitivity.
2018-1-8
reygun1
Tviscomi Posted at 2018-1-8 09:08
I can confidently say it does not affect screen sensitivity
2018-1-8
TomWolves
Thanks reygun1, I will give them a try.
2018-1-8
