image delay on panning shot
949 8 2017-11-27
djiuser_WvhJPJB
HI everyone
I just got my mavic few month ago and notice that there are always slight delay of the footage like the gimble suddenly moved a bit when I am doing panning shots. I use 4k 29.95 fps, iso100 1/60 shutter speed, very slot panning but dont seems to change the result. problem seems to be twice as bad when I am shotting 60 fps on lower resolution. Does anyone have the same issue?
2017-11-27
Ex Machina
Flight distance : 1806362 ft
Post a video so we can see what you are experiencing.
2017-11-27
DJI Thor
Flight distance : 13602 ft
Agree with Ex Machina, please upload an original video from SD card to Dropbox so we can have a visual understanding of your case.
And maybe you can try to format or change the SD card to see if it helps.
2017-11-27
djiuser_WvhJPJB
2017-12-2
djiuser_WvhJPJB
only noticeable when watching with HD, very slight delay, most noticeable aroudn 20s,
2017-12-2
djiuser_WvhJPJB
2017-12-2
Bekaru Tree
Flight distance : 15513100 ft
South Africa
As a tree climbing professional, a former sailor and current mavic pilot i wish to point out that the wind is absolutely pumping in yr video clip. i watched yr clip a few times but was not able to see yr problem however assuming it is there then i am going to take a guess based on this video that yr drone caught an extra gust of wind which caused the problem you see. Could you post another clip shot in calm weather to see if this problem is noticable?
2017-12-2
djiuser_WvhJPJB
2017-12-2
djiuser_WvhJPJB
at first I was thinking the same, but i notice that the delay happen around every 3s like the camera suddenly stop turning and want to quickly catch up after. maybe I am just imagining things but would like some second opinions.
2017-12-2
