Dockater
Flight distance : 139649 ft
Hi James, be aware that the type of solution used by Kuya Kano although effective is not a true “booster” it simply channels more of the available signal in the forward direction, you need to be very careful to remain facing the drone at all times, also when it is overhead. Count yourself lucky to be in the USA, in Europe we have our range SW and FW limited in comparison to you. As to warrantee limitations, you bet it is going to be your fault whatever. |
