no lightbridge connection with phantom4?
1119 11 2017-11-28
nickzavi
Flight distance : 137257 ft
Greece
http://app.airdata.com/main?share=kncNqu&page_id=SENSORS
[tr][/tr]
[tr][/tr]
4months ago i have strong signal and going 5kmh and now i have only 400meters. wtf is going on with the signal and the lightbridge?? i have downgrade to older version but the problem remains. i think with this new updates we have taken a hardware failure. i dont know im very disappointed. i have try olders versions of firmware 1 and the problem remains. maybe we have a hardware failure because of this crazy updates. failure updates.??? sory for my english. i have the log flights and the signal is poor
It's almost like the device is flying by wifi and not lightbridge.  I'm been going crazy all night trying to figure this out.  Anyone got any suggestions?
Thanks!
2017-11-28
Aardvark
Flight distance : 384432 ft
What happens if you fly in opposite direction away from any potential sources of interference on the 2.4GHz band ?
As you approach town there is more and more interference seen, which is quite normal.
2017-11-28
DJI Susan
Hey there, generally, the firmware update will not cause hardware glitches. You can check whether the antenna damaged or not and adjust the angel to see if it helps.
2017-11-29
nickzavi
Greece
Aardvark Posted at 2017-11-28 06:10
in the same place with older firmwares i have better distance about 4kmh and now only 400 meters! you can see the log flight i havent magnetic interface.
2017-11-29
nickzavi
Greece
DJI Susan Posted at 2017-11-29 00:44
i have send my controller for check up in dji. with older firmwares i have 4000 meters distance in the same place and now only 400 ??
2017-11-29
Aardvark
nickzavi Posted at 2017-11-29 05:20
I see in the flight log that there are lots of signal errors as you approach the built up area. Anything there might be causing interference that you did not see before. If you fly in an unpopulated area, what range do you get then ?
2017-11-29
nickzavi
Greece
Aardvark Posted at 2017-11-29 06:38
im flying in the same place more often and i have never had a problem with  signal until now with the last update. when i fly in the mountain i have the same distance and 400 meters only. maybe a control or bird hardware failure?
2017-11-29
DJI Susan
nickzavi Posted at 2017-11-29 05:21
So the maximum distance is 400 meters no matter where do you fly? Could you tell us your last case number? I'll look into the exact status.
2017-12-1
nickzavi
Greece
DJI Susan Posted at 2017-12-1 22:39
Yes Suzan the flight distance is only 400 meters no matter where I fly! I have this problems 3 months and I can’t find solution! Four months ago I have 4000 meters distance in the same places and 3 months now only 400 meters exact the same places! Please help me to fix this problem where is the last case number I can’t find
2017-12-2
DJI Susan
nickzavi Posted at 2017-12-2 08:01
Sorry for the misunderstanding. Per your reply in 4#, you said that you have send your controller for check up in DJI. Is it the official DJI service center? Is there any case number begins with CAS?
2017-12-3
nickzavi
Greece
DJI Susan Posted at 2017-12-3 23:06
yes official DJI service here in greece!
2017-12-4
DJI Susan
nickzavi Posted at 2017-12-4 07:57
I'm afraid the information you offered is not enough to locate the exact status. If the issue persists in every place, even the open location without any interference, I'd suggest to send it in for fully diagnosis: http://www.dji.com/support
2017-12-4
