So I suffered a crash into a tree, fell maybe 25 feet. I stopped the motors as soon as possible. Impact damage seemed minimal. The battery was slightly dislodged from A/C when I got to it. The battery lights were still on as if it was still plugged into the A/C. I plugged the battery back in and turned it on. Then turned it off and it took about 10 seconds longer to shut down. I turned it on again later to see if it was still operational and the A/C wouldn't connect with the remote. I tried a few things with no luck and went to turn it one. This is when I noticed the red light on the battery blink multiple times. The green lights turned off as usual. I thought maybe a battery issue? But I tried the my other battery that wasn't involved in the crash and the same thing happened. I can't find anything out there on this problem. Any help will be appreciated!
I looked at the battery contacts and everything appears to be ok. Nothing bent or dislodged. All wires are intact as well. I forgot to mention in the whole post that the A/C will not connect with remote.
fansed7c2fe4 Posted at 2017-11-28 17:06
No. A/C will turn on. Lights and gimbal operate normally. When i go to connect my phone to the remote, it shows the A/C as disconnected.
All pin connectors are connected. I unplugged and replugged. No luck. I even found a video on YouTube on how to reconnect the controller manually. (Press C1, C2, and record until it beeps. The press in the right knob that controls camera exposure. Then there’s a button on the sensor base to push). That didn’t work either. Frustration is setting in
DJI Susan Posted at 2017-11-28 23:28
I'm sorry to read your post. It looks like the drone was damaged in the crash. Please send it in for diagnosis and repair: http://www.dji.com/support
I'm not sure the specific turnaround. Please tell us your case number once you got, and we will keep follow up for you. Alternatively, you can check the case status from here: https://repair.dji.com/en/support/RepairTrace Feel free to contact us if there is any further questions.
