Crystal Sky and Apps!?
2305 16 2017-11-28
dkotinsky
Flight distance : 15096995 ft
Anyone install some cool functional apps into their Crystal Skies yet?
2017-11-28
DJI Elektra
I am curious about the recommendation. Please note that CrystalSky supports up to 20 third-party apps, but we are not responsible for any rights or information involving third-party security and does not provide any technical support for compatibility issues. Thanks for your support.
2017-11-28
Shoot It WA
Flight distance : 3576476 ft
Yet to find one that doesn't require google play services, tried DroneDeploy and Altizure can't get either to work.
2017-11-28
Shoot It WA Posted at 2017-11-28 20:29
CystalSky runs custom-built Android system, in order to ensure its stability, it doesn't support Google services Framework at the moment, sorry for the inconvenience caused.
2017-11-29
DTK
Flight distance : 1943159 ft
So Mindy, could you give some suggestions on what your choice of apps to be put on CS? Many of the prospect would like to know what else can be put on CS for their flight.
2017-11-30
Rodger8
Flight distance : 20145135 ft
I have a Crystal Sky and really like it. For my third party apps I am going to use my iPad mini 4.
2017-11-30
snath
Flight distance : 4803983 ft
DJI Mindy Posted at 2017-11-29 23:43
Crystal Sky has a defect because it does not refresh the flight records, most of the time it hangs and the application has to be re-started, it rarely completes for me and thus can't capture my flights using this platform.
2017-11-30
DTK
snath Posted at 2017-11-30 13:46
You are the first one complaining the stability of CS. Are you sure that it is not a defective unit? Everyone seems to be happy about it.
2017-11-30
snath
DTK Posted at 2017-11-30 16:10
Overall unit is fine, just can keep track of my fights to save my life, Reset it and lost some flights thinking that may do the trick but no luck. It just goes in an infinite loop and then have to re-start.
2017-11-30
Masemoto
Flight distance : 5137425 ft
snath Posted at 2017-11-30 18:04
I have a similar issue.  "Sync Flight Records Failed" is the message I get.  If I try to sync all records it takes 32 minutes (I timed it) to get to 100% and then the error message.  If I sync 1 month of records it takes under 30 seconds to get to 100% with same error. Rebooted the hardware, restarted the app... nothing helps. Any recommendations?
2017-12-1
DTK
"Sync flight records failed" seems not to be CS specific. DJI apps have similar issues in syncing flight distance as well.
2017-12-3
Hi, Snath, sorry for the late response, just to verify, the APP always freeze and the flight records cannot be saved, right? If so, may I know the current firmware of CrystalSky and APP version?
2017-12-4
Masemoto Posted at 2017-12-1 15:25
Hi, Sir, did you try to sync with other network?
Please post the APP version here, thank you.
2017-12-4
snath
DJI Mindy Posted at 2017-12-4 03:17
Hi DJI-Mindy
My current version is 02.04.02.00
I have lost flight records because I reset it and tried to re-do the overall records, no luck as it keeps running and has totally drained full battery on 2 occasions. I finally had to go back to my iPAD to capture flights. This is absolutely crazy. It also seems to have corrupted the Flight data header (see attached)
2017-12-4
Masemoto
DJI Mindy Posted at 2017-12-4 03:27
DJI Go App version = 4.1.14
System Version = 2.04.02.00
On Crystalsky I selected the "Clear Locally Cached Records" and selected "Clear All Cached Records", this appeared to erase all the flight records on my Crystalsky.  However when I then ran the sync for one month it was successful. The records from Crystalsky (I thought were deleted) sync'd to the central db and the records from the central db sync'd to Crystalsky for 1 month of history. Confirmed by syncing the go app on my iPhone and iPad records from Crystalsky appeared.
Cleared Crystalsky cache again and attempting to sync all records now.
2017-12-4
Masemoto
Masemoto Posted at 2017-12-4 17:53
Still can't sync all the records to my Crystalsky but as long as I can sync last 6 months or even 30 days I'm okay. Will use iPhone or iPad to view full history.
2017-12-5
Zane Isaac
Flight distance : 8712549 ft
Same issue here same sync issues I made a thread for it...
2017-12-5
