Do us drone users have to register with the FAA?
I have seen many threads of individuals stating that you must register with the FAA if you're flying a drone, others say you don't have to. For me, it was confusing trying to find an answer. So for the sake of helping others like myself who had a question about this issue, I looked up the requirements directly on the FAA's website and found the following info: (https://www.faa.gov/uas/getting_started/fly_for_fun/)
Drone owners do NOT have to register their UAS with the FAA if you fly under the "Special Rule for Model Aircraft (P.L. 112-95, Section 336)"
That "Special Rule" is described as follows, and I quote:
Note: Model aircraft operators that comply with all of these operational requirements during flight do not have to register their UAS with the FAA. Model aircraft operators must follow these rules to fly under this Rule: - the aircraft is flown strictly for hobby or recreational use
- the aircraft is operated in accordance with a community-based set of safety guidelines and within the programming of a nationwide community-based organization
- the aircraft is limited to not more than 55 pounds unless otherwise certified through a design, construction, inspection, flight test, and operational safety program administered by a community-based organization
- the aircraft is operated in a manner that does not interfere with and gives way to any manned aircraft
- when flown within 5 miles of an airport, the operator of the aircraft provides the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation (model aircraft operators flying from a permanent location within 5 miles of an airport should establish a mutually-agreed upon operating procedure with the airport operator and the airport air traffic control tower [when an air traffic facility is located at the airport])
A model aircraft is defined as an unmanned aircraft that: - capable of sustained flight in the atmosphere
- flown within visual line of sight of the person operating the aircraft
- flown for hobby or recreational purposes.
I hope this helps others out who are looking for a clear answer on this topic. For those who still wish to register their aircraft anyway with the FAA, that's fine, and you can do so under the "modeler" category. But if you are simply a hobbyist looking to fly for recreational purposes, you are not required to register.
Happy flying, my friends! Stay safe.
