Smerdyakov
RobAlbania Posted at 2017-12-4 15:08
Fault description:
There is a fault in the "second" controllers as supplied "out of the box" that prevents them pairing as a "slave" controller. Meaningless error messages such as "can not configure Country Code" are displayed on the DJI app.
Rob –
Thanks for the information. It would seem that my issue fits into the fault you describe. However, (maybe I should have mentioned this before) I purchased the controller, pre-owned, where is was used as a slave controller until the seller upgraded to a Cendence. So, I'm assuming it should have a controller ID when I received.
I did try making the second controller the Master. I linked the second controller to the aircraft, which should have given the controller is ID (I think), and made it the master controller and tried to get the controller that came with the aircraft to be the slave. Also, when I make the second controller the Master and enter an Authentication Code, the code disappears and the field remains blank.
FWIW, I've not gotten any error messages. When either controller is set up as a slave, it does not neither will find the master. |
