Bill in Ohio
I am planning to buy the Crystalsky Ultra 7.85 Display for my Mavic, and plan to use the Phantom 4 Advanced 160W power supply that DJI lists as compatible with the Mavic Charging Hub (Advanced) - that's good. Is there an adapter for the other cable on the power supply to allow it to charge the usb port on the side of the Mavic Pro RC. That would allow me to take just one power supply rather than two. If not, ask tech folks if they can make one, or if there is an adapter already on the market.
Thanks,
Problem Solved:
The Crystalsky, Phantom 4 Series Charger (160W), and Mavic Pro Charging Hub just arrived.
The CS Battery Charger uses the round connector input to charge the CS Batteries and on the opposite side, a USB Port out to charge devices that use 5V 2.0A. So my problem is solved - I just use a micro USB to normal USB cable to connect the Mavic RC to the CS Battery Hub. The other cable a bar with 12 connection points can power individual batteries, or with the Mavic Hub (Adv. or normal) charge the Mavic Batteries. I did not realize that the CS Battery Hub had a USB OUT port.
