RicardoGray
Flight distance : 4356421 ft
fans7858b1b9 Posted at 2017-11-30 12:29
I have not been able to take it up because of rain. So, it is just happening when I turn it on in the home, but this has never happened in the last year that I've been flying. I wanted to know if I take it up will this cause a problem or is it just a bug in the upgraded software?
I agree with all the others that inside is not the place to be testing. Understand the rain issue too, but give it a try outside when you can. Quick question though. Why not put the version back on you said you had no issue with? I'm guessing it is IOS, so if you don't have a backup on your computer it might be tough?
If it is android, you can get an older version pretty easy.
How about borrowing another device, even and android phone maybe just to try. I have a P3A and strictly am an android user and never had anything like what you are describing. I do have an I-phone I use for work, and I used to try it on my Phantom, but after the last IOS update, it won't even connect to the controller. I haven't spent much time trying to figure it out because like I said I have other android devices I normally use. |
