Problem with videos not being able to play
27979 26 2017-12-1
djiuser_qdMzQ2E
Singapore
Recently i have been flying with the drone and recording the views always, but when i took out the micro sd card and put it in my phone, i am not able to play the video at all, in the past when i did this, the video was playable and the video quality was tip-top condition. How do i rectify this issue?
2017-12-1
djiuser_CXijsR6
Flight distance : 134987 ft
Kenya
same issue
2017-12-1
S-e-ven
Flight distance : 5922034 ft
Thailand
Are that recordings, you did not stop to record, before you shut off the drone?
If yes, read here a bit:
http://live555.com/drones/DJI-Phantom-2-Vision+-video-fix/
2017-12-1
djiuser_qdMzQ2E
Singapore
S-e-ven Posted at 2017-12-1 05:42
Hi, I have not done anything of that sort that you have mentioned, im extremely gutted as this was never an issue when i was flying 1 month ago. I really need help on how to rectify this.
2017-12-1
Wachtberger
Flight distance : 261509 ft
djiuser_qdMzQ2E Posted at 2017-12-1 11:57
It very much sounds like you have switched off the Spark before stopping video recording in the App. Happened to me also a few times but I have learned the lesson. First stop video recording in the App, then switch off Spark.
2017-12-1
mtnlandpix
If you remove the SD card from the Spark, will it play on a computer?
2017-12-1
Hi, could you please answer Mtnlandpix's question? Will the SD card be recognized by the computer and will the footage be played? Do you use the stock Micro SD card?
2017-12-3
djiuser_qdMzQ2E
Singapore
DJI Mindy Posted at 2017-12-3 01:50
Yes, it will still be played when i put the sd card into a computer/laptop, but since im travelling on a budget i dont usually bring my laptop with me, hence i make use of the sd card in my phone to view the videos, which is much less complicated and bulky to carry.
2017-12-5
djiuser_qdMzQ2E
Singapore
Wachtberger Posted at 2017-12-1 13:50
How do i rectify the issue? Its still persistent after i stop recording and off the spark
2017-12-5
Wachtberger
djiuser_qdMzQ2E Posted at 2017-12-5 12:28
If  that is case there must be a different issue. Unfortunately I have no idea what it could be. Have you tried with a different SD card? Formatting the SD card with DJI GO4 might also be worth to try.
2017-12-5
SuperDrone
Flight distance : 186175 ft
Israel
easy... your player app cant play the video... try VLC?
because on a computer with a player that doesnt need codecs, it will play flawless...
so the problem is with the APP video player..
try VLC for android if thats your Device OS...
Edit:
yup just tried it myself and with samsung video app player it doesnt work..
and with VLC for Android it does...
i dont extract the SD from the spark i usually download it from the spark to the phone or directly to the pc...
its a codec issue thing.. as VLC will play anything with or without Codecs...
by the way the original downloaded files 1080p are on this directory on android:
sd_card/DJI/dji.go.v4/DJI Album/
2017-12-5
djiuser_qdMzQ2E
Singapore
Wachtberger Posted at 2017-12-5 15:13
I have tried eith different sd cards but its still to no avail.
2017-12-5
Wachtberger
djiuser_qdMzQ2E Posted at 2017-12-5 22:34
It is quite obvious that the problem is with your phone then because the videos are working on your Laptop. Look at post 11# how to solve this.
2017-12-5
djiuser_qdMzQ2E Posted at 2017-12-5 12:25
I agree with Wachtberger, it could be your phone issue, please find a computer to have a try if possible.
2017-12-5
SuperDrone
Israel
well i hope it worked out for anyone who had this issue :]
2017-12-6
djiuser_qdMzQ2E
Singapore
DJI Mindy Posted at 2017-12-5 23:34
I have tried it on 3 different phones of different brands, it still does not work.
2017-12-6
SuperDrone
Israel
when you buy a computer it doesnt come with all the supporting video codecs right? well thats how it use to be back then..
i figured its the same with phones as they are not different than a computer in general...
so you have to download some codec pack right?(which i dont, i use players that doesnt need codecs, but before i found that out a long long time ago, i used to download codecs pack and install them)
and after i would install them every video worked.. dont try to switch phones... because its a player issue... DJI doesnt need to check every player to see if they are working with their files or not.. its a user duty to do so..
2017-12-6
Z42A
Flight distance : 925807 ft
I'm running into a similar issue with my Mavic Air.
2019-6-15
Z42A
I'm getting the same issue with my Mavic Air. I can see photos, but the videos won't download to my iPhone (worked fine a few months ago). It says that only H.264 video can be downloaded...but the format IS H.264 that's being recorded. No idea why they won't talk to each other. I can use iMovie on my laptop to edit videos, but I can't view them or use the easy editor in DJI Go 4 to see or edit them on my phone. Is this due to an OS update on the phone? Is my app messed up? Is it the drone? UGH!
2019-6-15
Kimberly Tapiwa Kujinga
Zimbabwe
Help i recently took some footage on my spark, then downloaded the video from the my app, i am trying to send the video to my friend via whatsapp it refuses however i sent her another video i took so a little confused.
2019-7-2
S-e-ven
Thailand
Kimberly Tapiwa Kujinga Posted at 7-2 20:34
Can it be, that the video is just to big for whatsapp?
Split it, resize it, use the 720p file from your phone
2019-7-6
Syed Talha
Try to change Format
2019-9-15
djiuser_HhncBRaUzjog
I had this same issue, I forgot to stop the recording. Dose that mean the video is corrupted
2019-12-7
Village Video
Flight distance : 23301 ft
Sounds like you are shooting in a format your phone can't play
I would check by recording in 720p If that works the problem is the quality of your phone...just my guess
2019-12-19
Camile Dai
Japan
To isolate the problem, you can
1) convert DJI videos to H.264 MP4 using VLC.
2) record videos in a lower resolution, for example, 720P or smaller.
See whether they are playable on your iPhone.
2019-12-22
uncomnizm
Flight distance : 175187 ft
This could be an issue with your phones lack of memory/storage, or maybe it could not.
2020-12-29
djiuser_d32laoKfHdVc
Es8 drone won't connect video to the ufo app on any phone or tablet
2023-3-27
