finding lost drone with app map
4235 18 2017-12-1
fans2396b4e2
Flight distance : 283261 ft
My Phantom 3 standard went down in a park.  I used the tracking map in the app to locate it. I assumed that the red triangle is the aitrcraft and the blue dot is my location. It led me to a spot near some trees.  On the ground were a couple pieces of prop blade but the aircraft was nowhere around.  The ground had leaves but no underbrush. There were some trees but they were bare and you could see 99% into them. I looked around for hours knowing that it had to be there.
My question-If the red triangle still appears on the map does that mean the the aircraft is there?  I know i'm not going blind but I just can't find it.
2017-12-1
Dockater
Flight distance : 139649 ft
As long as the ac is alive and connected it will send its position back to the controller. You would indeed appear to have found it, if you have found bits of propeller then the ac will not be far off, without props it cannot fly and without legs it cannot walk. Has it possibly been found by somebody and taken away?
2017-12-1
ALABAMA
Flight distance : 10442687 ft
How long has it been lost?  It may be giving you it's last known location. If battery ran down, or someone picked it up and cut it off.
2017-12-1
Michgolden
Flight distance : 822851 ft
I hate to say it but i would have to agree that it seems someone may have picked it up. Is this part of the park usually occupied by people? The AC should be fairly close to the prop pieces.
2017-12-1
DJI Susan
Hello Sir, I'm sorry to hear the crash. Generally, the last GPS coordinates indicated the place where the connection lost. And it's hard to predict the direction if the drone was blown away or picked up by others. Good luck.
2017-12-2
Nebuchadnezzar
Flight distance : 3462946 ft
in case of accident, the drone should be put in beacon mode, and be able to locate it via wifi, it would be possible, maybe
2017-12-2
WD9EON
Flight distance : 686886 ft
Did you have it marked with your contact details in case someone finds it, they can call you?
2017-12-2
allyssongemelli
Flight distance : 2562467 ft
Brazil
So let me understand, if the battery ran down, or it's off, it will located the last position? And after this, it will not show the precise location?
2017-12-2
RADROCKET
Flight distance : 1110827 ft
Check your local lost and found adds at this point.
2017-12-2
fans2396b4e2
RADROCKET Posted at 2017-12-2 06:10
Thanks.  it's still a mystery.  I was standing on the spot where the final video was showing the ac on the ground.  The red arrow still was showing on my phone but someone must have seen it go down and grabbed it and turned it off.  I was there in 15 minutes.
Anyway, DJI anyalized the flight data and replaced it.  Great company. It was a fly off failure.
My contact info was on the ac  along with "reward"and I checked Lost and found.
Thanks again for your help.  Bill B.
2017-12-29
ALABAMA
Glad you got it replaced!
2017-12-29
RedHotPoker
Flight distance : 165105 ft
ALABAMA Posted at 2017-12-29 07:42
Glad you got it replaced.
Yes, that's great to hear.
RedHotPoker
2017-12-29
stuka75
Flight distance : 85682 ft
Had a P4 go into bare trees this December in woods. Found bits of broken props and looked in the tree for over ten minutes before we saw it. We looked right at it multipl times, but never saw it. FWIW.
2017-12-29
Badbobstikibar
Flight distance : 620112 ft
Happy ending for sure. Drone on
2017-12-29
Bashy
Flight distance : 2354357 ft
WOW, 1 up to DJI, great ending
2017-12-29
Quest4Life
fans2396b4e2 Posted at 2017-12-29 06:35
HOw did you go about getting it replaced?  I have the DJI Care option on mine, and my DJI Pro 4 did the same thing yesterday, I fly at my 161 acres all the time doing 3d modeling/maps, it takes off, does it's thing, comes back and lands....it never came back this time, and my dang tablet batter died about 5 minutes after that so I lost the position/visibility.
Any advice would be great.
2018-2-21
fans2396b4e2
You should contact DJI tech and they will tell you how to let them access the cloud with your stored aircraft flight data.  They should be able to tell what happened and what caused it.  I wasn't looking for a replacement but they studied my data and determined that they would offer me a replacement.  Good luck with your quest.
2018-2-22
Jeff Millard
Flight distance : 503635 ft
fans2396b4e2 Posted at 2018-2-22 17:52
+1 for uploading your flight data huh? Good stuff right there!
Jeff
2018-2-23
fans2396b4e2
Go into your app on the  tablet and look up your flight records. You can watch the video that was being taken when the drone went down.  You might recognize landmarks, trees, etc. to help locate the spot. It's all there on your tablet or phone or whatever you were using.
2018-2-24
