Never Fly Faste
Flight distance : 3044747 ft
Please allow me to describe the sequence of occurance.
1. When returning home from my maiden flight a firmware version check was done while I was replaying my recording just made. I updated the firmware as requested.
2. While installing the update a system (controller went black screen) crash occured. The controller recovered and the message to download the firmware again showed up. So I did, with the batteries well over 50 % remaining.
3. The second install was succesfull. As I disconnected the USB cable to the drone a renewed version check was executed telling me to update my fIrmware. Odd, as I just did, but I connected the USB cable to the drone again and pressed update.
4. While in firmware update, as I assume, it showed to update the No-fly zone. So I pressed continue. The first 60% went really fast than the system got stuck at 60%. I waiting anohter 30 min. with the update holding at 60 %. Than the battery went so low that the system (aircraft first) turned itself off.
4. After loading the aircraft battery and controller battery seperately to avoid overheating of the charger I turned on the controller and next the drone.
5. Again a version check request appeared. I just finished it and all looks fine.
6. Although it tells me to update the No-Fly zone I'm very hesitant to do so.
So, I fine for now, But please advise on the No Fly zone. Thanks in advance.
