Punchbuggy
Flight distance : 483166 ft
Hi Pete. Apologies if you've already read and tried this.
Sometimes when you've updated your craft via the GO app it reports "Installing..." at 99% when in fact it's been completed. The clue is if the craft rebooted itself when on the 99% - that's it completing the installation. If that happened, then you're safe restarting the app.
The controller is blinking red/green because there's an update for it. With craft turned OFF, connect your smartdevice to the controller, power on the controller (only - craft stays off), then start the GO 4 app. It should say that it's collecting version information, and then you enter the device. At the status update (top left line on screen) it should be advising that there's an update to v1.9.3 - let it do it.
You may need to manually re-link the controller to the craft after that. Also, if you updated your P4 to firmware v...0106, you may find that the P4 flight is erratic. If that's the case, PM to one of the DJI mods requesting access to the beta v..0600 - they will need your DJI account email to allocate access. |
