DJI Diana
Flight distance : 2408 ft
Hi Bob, Moto G5 is not on the recommended device list, but you can still try to remove the APP, then install it again, see if it helps. You can also enable the airplane mode when this APP is running. If it persists, I would recommend you use an recommended device, here is a list for your reference only.
