DJI Diana
Flight distance : 2408 ft
jracz Posted at 2017-12-6 03:01
Thank you.
Reg, new restriction: I understand, that should I use DGI GO or Litchi, I'll still be able to fly up to 120 m, right?
Reg follow terrain mode: does it work in a steep mountain? In this case, does the aircraft ascend or hover?
For the new restriction, you won't be restricted if you logged your DJI account into the DJI GO 4 APP. Like Aardvark mentioned, you only need to log into it once when you have internet access, then don't log out it. After that, no internet connection is needed to fly.
For the Terrain follow mode, this mode is designed for use on grassland sloped at no more than 20°. Here is a screenshot for your reference, for more details, please visit: https://dl.djicdn.com/downloads/ ... ser+Manual+v1.6.pdf
