Dockater
Flight distance : 139649 ft
Peterx Posted at 2017-12-7 13:02
The Go app also has "Home Lock" but it´s not headless,headless is "Course lock" just like the Xin Lin X161 Follower X6. Home Lock is,if you pull down the right stick(in mode2) then the copter is flying toward the home point. It equal what direction the current position of the copter to your position is.. If you use "Course Lock" then you can set and reset the direction of your copter before flight(during hover on place)
Set the nose of the copter exactly to North and tab apply on App and the copter will fly to northern direction if you push the right stick up,eastern direction(stick to right) west (stick to left) and south (stick down) .
The copter will continue the flight from the stick input of the right stick,and will not return automatically if the copters signal is available and enough power is on the battery.
Of course Peterx, you are perfectly right, I had completely forgotten „course lock“. That is indeed very similar to the mode used by Yuneec but that orientates itself only on the operator. Keeping for example right stick will fly a circle around the operator and backwards will return to operator, forwards stick will fly directly away from the operator. |
