SunSets
Flight distance : 311089 ft
Hi, I received my new Spark and Controller this morning. I watched many video's over the weekend for newbies getting up and running. I read the manuals online and the micro-manuals shipped with the model. However, I may have already damaged the battery. I plugged in the usb micro plug into the drone, the other end into the charging brick then into the wall. There was no indication the battery was charging. I cycled the battery on while still being pluged into the outlet. Then thought that can't be right. and turned the battery off. So I plugged everything back in again without turning on the battery....After a little time I disconected the charger from the drone. And turned on the battery to check if I had more solid lights to indicate it was charging. No change, only one light was solid and one flashing. Thats same as it was when unboxed and checked for first time. Question, did I damage new battery by turning it on while still plugged in to the outlet and connected to the drone? And, Is it normal that no light to indicate it's charging while plugged in? I had noticed 1 green light flashing while a person used a power pack on youtube. Should I just wire it all up, plug it in and come back in a hour or so, discount it and power on the drone? When the answers arn't clear to me this is what happens.
