hallmark007
Flight distance : 9827923 ft
Javey Posted at 2017-12-6 17:43
Here's the link. As you can see, battery was low at about 22% and was just finishing a pano, was not hit by a bird or a tree as I was well over 20 ft above a tree and hovering so it's not possible. Battery was fine, 16 satellites, within LOS and no connection errors, and it crashed less than a second after the error so no chance to retrieve it or land it as I was 100+ ft away. There's no rhyme or reason for the crash. I do see "Speed Error" however I was hovering and not even moving! I saw on my screen a Motor Overloaded error but how? I just don't understand.......
Flight Log
Looks like motor overload was the cause of your problem, whether it was a cracked prop or something else causing aircraft motor overload I wouldn’t like to say, but when this happened your aircraft motors slowed right down causing it to slowly descend this is most likely a reaction from IMU to try to maintain attitude ,it was still in pano mode starting at 95ft and finished pano at 22ft, I presume it would just have landed but hit a tree, this is where you see speed error, you can see in your log last couple of seconds you were pushing forward on the throttle trying to gain altitude but no reaction from Aircraft.
I’m not 100% sure what happens when you have motor overload at altitude but it looks like from your log that all motors slow down causing Aircraft to lose altitude this was happening at slow enough speed that if nothing was under the aircraft it would have reached the ground reasonably safe.
So I think this one will be up to dji, it doesn’t look like any fault with the pilot, I hope they find in your favour and replace your Aircraft.
Good luck. |
