Vonderis
Republic of Lithuania
DJI Susan Posted at 2017-12-5 20:26
Hey there, which type of mobile do you use? The issue only appears in the live video, instead of the original video in SD card, right? Does the issue remain if changed to another recommended mobile device or another open place without interference?
I use the Samsung s7 and yes it only appears in the live video, everything on the SD card is perfectly clear. Haven't had a chance to test out another device (the phone worked fine before) or a different location because of a combination of bad weather and lack of time, but when I do get around to it I will try messing with the different signal channels and also hooking up the phone and remote with a usb cable |
